damon healy
30 points
Posted on - 08/22/2012
I have been trying to update my Ultimate fix using the guidelines that were provided. I must say that while the update was successful, another pop up window appeared from my launcher that required that I updated to 1.33.
I resorted to a manual update but still it didn’t work further blocking me from logging in. Installing the world adventure has also been blocked with the same error message being produced in each occasion.
>SetupNewsetup.cpp (143)
PAPP:
PVENDOR:
PGUID:
@Windows XP Service Pack 3 (2600)
IE Version: 6.0.2900.5512
         OK
Please help and tell me what possibly could be wrong.
Problem with the updating of Ultimate fix
In the error box it can be seen that you are using an old version of Internet Explorer. The older versions do not support most of the software available today. So i would suggest you to download the latest internet explorer and install it.
1. Go to https://support.microsoft.com/en-us/help/17621/internet-explorer-downloads and click on "Download Internet Explorer 9".
2. Save the file on your desktop.
3. After download completes, install the IE 9 on your computer. See the screenshot below:
4. Restart your computer and try to update Ultimate fix.
This should solve your problem.
