I am having trouble with my KM player, and I cannot set the subtitles.
There are some files showing dual sub, but I do not show how to turn them off or on.
I need to know the process of uploading subtitle on the screen using KMP. I am facing trouble with good movies in other languages.
Please someone help me.
Alden Clayton
Problem with uploading subtitles with kmp
Inserting subtitle on the KM player is not a problem. Just play the movie, then right click on the right top corner > go to the Lunch Subtitle > then select the subtitle file.
Make sure that you have the right extension for the subtitle. Generally subtitles are .srt files. Another important thing is, subtitle only work on the original version of movies. It will be an easy job to name the subtitle file as like the name of the movie file. For that the subtitle will automatically add up with the movie when you play it.
Except KM Player there is another player named VLC, it also plays subtitle along with movie, to do it, just drag the subtitle file over the player.
You can download subtitle in different language from the following site: https://subscene.com/
