Problem in Uploading Videos to Youtube with Live Movie Maker 2011
ney steele 20 points N/APosted on - 05/28/2012
Hi experts I need help with my Windows Live Movie Maker 2011. I cannot upload videos to Youtube anymore. I tried IE, Chrome and Firefox but they gave me the same error. It goes: 'my movie.wmv wasn't published successfully' The following problem occurred in your movie 0x80048008.
It seems that there is no problem with your Windows Live Movie Maker. Try to uninstall it and then reinstall it back. You can also try the YouTube Movie Maker which is a very simple and constant software.
You can use it to create and upload YouTube videos from frequent songs, images, text and more. Simply add your video to the video line and then click Publish to YouTube and its done.
It will automatically convert your recently added videos on YouTube and view it afterwards. Just go to your YouTube channel and then select the video you just uploaded.
I think the application you are using to upload your video to YouTube is already not working right. But when you said that even any of your web browsers didn’t work as well, there’s probably something wrong with your computer.
Try checking your computer first for any sign of infection. Update your antivirus then run a full system scan on your whole computer. Be sure to scan the folder System Volume Information located in the root of every drive because this is the favorite spot of most Trojan worms.
Make some changes in the Folder Options to view hidden files and folders because this is a hidden system folder and doesn’t normally appear on Windows Explorer.
If your system is negative for any sign of infection, the next to check is your system. Check your computer for any possible errors. Use a disk utility application to check the system.
You should also check your computer’s internet connection. Check if your internet cable is not unplugged at the back of your CPU and make sure that it is properly inserted in the network card.
After checking this part, try visiting some web sites using any of your web browsers again to see how stable your internet connection is. You should also try watching streaming videos in YouTube to see also how fast the video will buffer on your machine.
The speed of the video buffering depends on your connection’s speed. Stop uploading the video if you currently have a slow connection. Try uploading the video again during off-peak hours.
1....
