urzula
Posted on - 11/01/2011
Hello there!
Please help me, I am having a problem with the usage of my CPU.
I have this C# Console Application that locks up my Windows 2003 server whenever I try to run it.
I tried quitting the application but the UI was not responding to mouse clicks.
I need to know if there is a way for me to configure the C# Console Application so that it would not take up more than 50% of the CPU usage.
I would also like to know if .NET framework has a global setting that will allow me to monitor the applications so that they do not take over the machine completely.
I hope you can give me the answers I’m looking for.
Thank you very much…
lee hung
75 points
Problem with the usage of my CPU
Hello Urzula,
I will suggest for you one program that you can use to check the CPU usage of the applications on your system and which can allow you to regulate how the applications use the CPU. The program is called hard disk sentinel and you cam find it for free online.
Hard disk sentinel will help you in determining the, finding, diagnosing, testing and repairing any issues that your hard drive and the cpu may be having. With hard disk sentinel you can note the temperature usage, the hard disk health, and the amount of memory being used by the cpu. You also get to view the fluctuations in the performance of the system and any other failures that may occur.
__
Regards
Lee Hung
