Problem to using Mozilla Firefox 7 beta
If i wants to use Mozilla Firefox 7 beta in my pc it always create a loading problem, sometimes it get disconnected.
But if i run opera mini it doesn't create any problem
If you are having a problem using Mozilla Firefox, uninstall it and then do a disk check on your hard drive. If you are not familiar on how to do a disk check, here is how:
Wait for the disk check to finish and then install Mozilla Firefox again. Mozilla Firefox 7.0.1 is the latest version. If your version is the older one, you may want to download the latest release in Mozilla’s website: https://www.mozilla.org/en-US/firefox/.
If you are still having problems while using the latest version, check your internet setting for any proxy connection.
