Problem in Using Skype application
I am regular Skype user.
My Skype is getting more and more slow day by day.
Its takes a couple of minute to login and after login when I want to calling someone its says an error tag contains end tag and then its automatically logout from my account.
Skype
Unexpected end tag: expected "b", actual "font"
What can I do now?
Answered By 0 points N/A #82280
Many users have experienced this kind of error but I do have the solution to fix this problem.
1. Look up for Tools, then select Options. Click the Notification Settings and the go to Alerts and Messages
2. Remove all the check under the Show Messages About. Do this as well on the Show Alerts From
3. If its possible, try to disable Automatically disable Extras. To do this:
  • Look for the Tools menu
  • Select Options
  • Then go to Advanced
This option is not required but you can try doing this in case there are still errors.
This solution is tested and works fine. I already tested it in my computer as I get the same error on my Skype application on my Windows 7 operating system.
Hope this solves your problem.
