I face a particular type of problem while using the software photo shop.
The problem is sometimes while working my tools stop to work. It is very irritating while doing some important work.
What might be the reason for it?
Is there any sort of option need to be adjusted or whatever please help me out.
Problem using the softwer photo shop
Dear Jerry,
That issue arises when your system is having difficulty running photoshop or when photoshop is not getting enough resources out of your system to respond promtply while you work on it. I would first ask you to double-check your system specifications with the ones advised by adobe for using adobe photoshop. The recent versions of photoshop like cs5 and cs6 are heavier compared to the older installments.
The following link will take you to the system specifications for both PC and Mac for running Adobe photoshop CS5 smoothly and efficiently.
http://www.adobe.com/store/en_us/popup/software/photoshop5extended/systemreqs.html
Please read whichever one applies to you.
In case you are falling short, the you would need to upgrade your system in order to solve he problem.
Regards
