Problem Using with Winamp Player
I have used Winamp in a long time but it's only now that I've had problems with it. I was opening a .MOD video through Winamp, then this error suddenly pops out:
Module Plug-in Error
I appreciate your help,
Chad
Chad
Load some music files into your playlist and start playing some music. Installing DirectX; doing these two things (especially the first) will fix 99% of problems. For this plugin, you will also want to choose Maximum Framerates that divide evenly. If there is an error, it will display an error message in the upper-right corner.
Hi Stephen Vanness
Try these solutions
1. Go to general preferences in winamp
(Winamp, ctrl +P)
Then select Playlist
Inside the middle box, make sure it has “mp3” as an extension file. (Default is “MP3”)
2. Reinstall the winamp
Hope above mentioned solutions will rectify your problem
Thanks & Regards
Mckinney Ma
