Problem with viewing Adobe Bridge
I am using Adobe Bridge CS5. The images in the last row on the right side of the frame are cut off.
I have tried expanding the frame and also tried changing the thumbnail size but nothing worked.
How do I go about solving this problem?
Answered By 0 points N/A #108100
You can do this by previewing images in the previewing panel. This can be done in full screen previews and in the reviewing mode. In preview you get the full screen view so you can view images in full. It also lets you do navigation to the images. You are also able to refine your selections, do rating, labelling and rotating of  images. You are also able to open images in camera raws.
Doing the preview you should get one or two images selected, then view > full preview screen you can also press the spacing bar. You may use the plus (+) or the (-) sign to either zoom out or in. To move to the next image press the Right or left arrow.
If you want to exit then use either the space bar or the esc key.
