Moose Lodge
20 points
Posted on - 01/13/2012
There is a problem that when open internet explorer, the home page shows with random words that are underlined and it showed no apparent reason for this. When clicked on a new browser it opens with `search miracle’ giving changes to homepage. Why the internet explorer home page is with some underlined words and how could I delete search miracle which gives changes to homepage?
Problem in viewing home page
Hi Moose,
It may be that your internet explorer is corrupted or your computer is infected with a virus or spyware. Virus and spywares tend to bend the display we should have and route our homepage to another site. This usually happens if you have tried to download something from the internet or may use a toolbar as well.
Try to run a virus scan using your antivirus application. Try to also run your antispyware and antimalware applications.
You may want to repair your internet explorer by going to the control panel and repairing it. Worst case scenario is you need to take out the internet explorer then install it back.
