I had a problem playing my videos!
An error appeared when I was processing for the playing of the videos with the use of Virtual Dub. I was selecting the Save As AVI, I just want to change the format to AVI at this point.
Here is an image regarding the error:
VirtualDub Error
Video compression error: The source image format is not acceptable.
(error code-2)
I need help please.
A problem with Virtual Dub software
AVI files are composed of common streams; that one consists of one movie and something audio tracks flow. You could shop text channels and also numerous car stereo avenues in a single AVI record. (Virtual Dubs AVI parser supports multi-video as well as multi-audio flow AVIs; it does not take UI and output quests in which don't.)
Audio and video data is saved in the 'movi' Record portion in chronological purchase. (This is simply not actually true of MUSTUSEINDEX is set within the supply headlines, yet I've never seen this kind of used.)
With the header being at the front end which means AVI files can certainly be took part in buffering mode across a system. They won't enjoy which properly considering the fact that AVI doesn't interleave information carefully sufficient, doesn't always have struggling components with regard to improved audio problem covering up as well as doesn't possess a inflexible adequate structure for good problem recovery, however it is possible.
Video and audio info are damaged into obstructs as well as combined together; each video frame possesses his own chunk, yet sound details are organized inside tiny packets. This is actually the "interleaved" the main document.
The reason behind it is so that the player can see the particular AVI document sequentially as well as grab the video and audio It takes without having looking for everywhere.
This is simply not also very important to play from the hard drive, and also modern day participants are incredibly good at managing non-interleaved or perhaps terribly interleaved documents, yet correct interleaving is critical for appropriate Play in inserted devices and CD-ROM Play.
Note that regardless of common perception, the interleaving of car stereo pieces is not related to the moment from the streams, and therefore no influence on sync.
AVI data files are composed associated with widespread avenues; that you consists of just one motion picture then one sound files circulation.
You could lock text channels and as well numerous car or truck stereo system strategies in an AVI document. Virtual Dubs AVI parser helps multi-video along with multi-audio circulation AVIs; not acquire urinary incontinence in addition to output tasks by which tend not to.
Sound in addition to video data can be preserved inside 'movie' Record percentage inside chronological purchase. This is just not really correct associated with mus use index is determined inside the supply days' news, still We have by no means observed this kind of utilized.
Using the header being at the front conclusion which means AVI data files to include took a portion inside loading setting around a process.
They don't get pleasure from that properly now that AVI will not interleave data thoroughly sufficient, will not have striving parts pertaining to enhanced audio tracks dilemma protecting way up along with will not employ a rigid ample design for great dilemma recovery, however it is also possible.
Online video media in addition to audio tracks data are ruined into hindrances along with combined jointly; each and every video frame includes his or her own piece, still sound information are structured within tiny packets.
This is actually the "interleaved" the main doc. The real reason for it's so that the person can see the exact AVI doc sequentially along with grab your video in addition to audio tracks.
It will require with no shaking all over the place. This can be not also essential in order to perform on the hard drive, and as well modern day participants are incredibly effective in controlling non-interleaved or maybe horribly interleaved papers, still accurate interleaving is vital intended for ideal Participate in inside introduced equipment in addition to CD-ROM Participate in.
Remember that no matter what widespread belief, your interleaving associated with car or truck stereo system items just isn't in connection with as soon as on the avenues, and for that reason simply no effect in synchrony.
Hope it helps you.
