neil guyson
Posted on - 04/02/2013
Hello Techyv Users and Experts,
I am encountering a problem with virus fill cleaner software on My Windows XP PC. I am using Avira antivirus software on My PC. I am not able to start the scan using Avira antivirus on my PC after the system crash. Please help me out to rectify my problem.Â
Thanks in advance.
Problem with virus fill cleaner software on Windows XP
Hello Neil Guyson,
Six months ago I have used Avira antivirus free version and look like works fine for me. But day by day my PC is getting slow and I have noticed that my PC is affected by the virus. Then I update the Anti Virus database. But it doesn’t work. I have lost lots of my important files.Â
After this I skip to use any freeware. So I am advising you to avoid freeware. I am sorry for not giving any solution for this issue. Now I use Kaspersky Internet Security 2013. First you may go for its 30 day trial version.
