Problem with visualizing hidden files – technical support required
        30 points
                                        Posted on - 04/04/2012
I cannot visualize some of the hidden files. In fact I do not know the method which will help me visualize it.
I need to inactive the hidden command soon.
Kindly someone help me with the technical solution and help me visualize the hidden files.
Kristan Lai
