Problem of VoIP apps in android
Why is the VoIP apps I install in my tab running Android OS not working? I have installed many VoIP apps such as Skype, Viper and many others on my android tab but none seem to be working. The apps are installed properly, but getting them to work is the challenge. Are there other settings after the installation? If there are, what are the settings?
