Josh Pikee
Posted on - 06/16/2012
Hello
I faced with a problem when I am using the Chernclient.
I’m trying to fix it for the last 4 hours but nothing has change on it. I’m seeing this error which shows a few seconds after l launched chernclient.exe.
We were unable to connect to the server. Please make sure you have a stable internet connection. The server might be experiencing some problems, do you wish to start the client anyway?
Thanks for any help you can give guys.
Problem when I am using the Chernclient.
If this is the first time it happened on your Chernarus Life Ultimate [ChernClient Online] game client, try restarting your computer then try it again. If it still doesn’t work, check your internet cable at the back of your CPU if it is properly connected. Open your web browser and visit some web sites to test the stability of your connection.
You may also try watching some streaming videos just to test the current speed of your connection. After verifying that your connection is fine, try opening the game client again and see if it works this time.
If it still fails, you may try reinstalling the game. Uninstall Chernarus Life Ultimate [ChernClient Online] from your machine then check your computer for any possible errors. Use a disk utility application to check the system. Install the game again after this then check if this fixes the problem.
For other comments and information about the game, you may visit Chernarus Life Ultimate *With Stats Save*.
