Problem when I installed Adobe Photoshop in Linuz-Debian.
Hi all,
I have got a problem. I’ve just installed Adobe Photoshop in Linux-Debian.
But whenever I want to run this, an error message appears (see image below). I have re-installed it again, but that didn’t fix the problem.
I’m not really familiar with this, so I need some help here.
Thanks in advance.
Program Error
The program Photoshop.exe has encountered a serious problems and needs to close. We are sorry for the inconvenience.
This can be caused by a problem in the program or a deficiency in WINE. You may want to check https://appdb.winehq.org/ for tips about running this application. If this problem is not present under Windows and has not been reported yet, you can
report it at http:/ /bugs.winehq.org.
