rachel91
Posted on - 10/10/2011
I'm using Firefox Mozilla. I want to listen to music from such the site mp3. zing.vn, but I can not listen online and I must download the song to my PC when I want to listen. Previously, I could listen to music or videos on the site but now It no longer, I must download music .
Please help me!!!. Thank you so much.
A problem when I listen to music on Firefox
There is a system of plugins in to the Firefox which contains and playing a random music is not from any of the opened tabs that have been happening from few weeks. Must be really play a crappy music and please disable all the Adonis from the Firefox. When you are opening a website for playing the music through the plugins. So when you open a site in a next time than a list of sites have been shown here for your check that what you have opened early and what do you want now. If you close these opened sites one by one until the music should be on here and it play very frequently.
There might be a problem with either your connection or your web browser.
Solution 1:
Reinstall your web browser or update it but it is much better to remove it first the install it once again and see if this will fix that problem of yours
Solution 2:
Check your internet service provider because it is also possible that you are not receiving any packets for viewing or listening in the internet.
Solution 3:
Try a different web browser and see if you can hear something. You can use Google Chrome, Safari, or Internet Explorer to test this problem of yours. And if you still want to use Firefox even if you tested it only with this browser just do solution 1.
