Problem when I try to select tables at the Or xor msSQL.
I have a problem with my Or Xor Mssql. It was working normally until now. When I try to select tables anything freezes. What should I do? Should I re-install it, or can I do something else?
Hi RobertCBusch,
It is confusing because you used so many or there. If it is MySql then I can suggest you, just take a backup and then start testing anything else. Best solution is reinstalling but before that you may try phpMyAdmin or try MySQL Front. Hope you understand the point. Thanks
Hi Robert C Busch,
 It is bit confusing though but I will suggest you to check constraints in procedure. If you are missing it at the time of inserting a record in table.
 In such case if you are missing constraint you may face such type of problem. If this is not working then I will suggest you to re install the application it should work for you.
