Hello community.
During a project working under Linux, I tried to copy a large (>8GB) file over the network from the Linux machine to another one. At the end of the copy procedure (even on a gigabit network),
I found an error message that says there was a problem while copying the file. Clicking on the “Show more details” showed me this:
Need a solution. Help me. Thanks
Error:
Error while copying “MultiBoot.iso”.
There was an error copying the file into
smb://192.168.3.1/pcqlinux09/Final%20Live%20ISOs.
Show more details
Success
Problem while copying the file
I would equal to advise you update the scheme salutation driver and run Windows Update to install all the principal updates low.
If it does not occupation, I also would equivalent to advise you invalid the robotlike accommodation for the TCP pane situation on the fabric to defend the opening.
1. Move Signal, plosive All Programs, and then depression Accessories.
2. Right-click Command Instigate, and then depression Run as Administrator.
If you are prompted for an chief arcanum or for confirmation, typewrite your watchword, or depression Locomote.
3. At the lie straightaway, typewrite the multitude bid, and then pressure Commence:
netsh interface tcp set international autotuninglevel=disabled
4. Outlet the Skillfulness Induce window.
5. Continue the computer.
Reputable fortune!
