gran wesner
20 points
Posted on - 07/27/2012
Hi all,
I just got the most up to date version of Avant and installed it. A message came up telling me to do so.
When I try and open it or use the URL, a white screen and the following message appear:
XULRunner
Error: Platform version '11.3' is not compatible with
min Version > = 12.0
Do you know what I can do to solve it?
Lots of thanks.
Problem while opening the latest version of Avant
There’s actually just an incompatibility issue with the min and max version of the program with your browser.
Try doing a fresh installation of the browser then see if the problem still exist or download a different browser and then try it out and see if you still have the same problem.
If so, try to do a repair of the said browser by right-clicking on it in the “programs and features” menu on the “control panel”.
Hope this helps.
