A friend has recommended Microsoft Office Professional 2007 to me, so I decided to install it.
When I run the program, the following error message appeared:
Windows -No Disk
Exception Processing Message 0xc0000013 Parameters 0x75BE023C
0x8343FCBC 0x75BE023C 0x75BE023C
I have already reported the issue to Microsoft, hoping to a quick solution.
Does anybody know how to fix it?
Please help.
Problem While Running the Microsoft Office Professional 2007
hi there,
many reason to created this problem ,
first
1 . your software not installed properly.
2. your software data broken
3. if you have any anti virus then anti virus bloke any file
4. and your software was damage
Hi Dear,
You can try out the following steps to sort out the problem….
1) Restart your PC and run the Microsoft Office Setup immediately after restarting.
2) Download and install the latest updates from the microsoft and then try installing the MS Office again
3) Empty about 1 GB of space in your drive where you want to install the MS Office 2007
4) Moreover you can also use some Anti Virus to clean your computer and then try installing the software again.
Good Luck
