Hello Guys.
Recently i can use my Windows Live Movie Maker Beta installed on my pc but this week when I try to open it, I get a pop up error
I don’t have a choice but to close it. Do i have to download a new trial movie maker?
Is there any way i can open Windows Live Movie Maker Beta again?
Windows Live Movie Maker Beta:
This trial version of windows live movie maker beta has expired. Would you like to see if there is a new version?
Problem with Window Movie Maker Beta
I think the problem is that you only use a beta version of the Windows Movie Maker. You should just download the final and stable one of the program. You can just simply search Google for it and just click the links that will go directly to the Microsoft website. Once there look for the Download Now button to start your download. This is a web installer so installing it will require more downloads. Just wait for the installation process to finish and after that, you can now run the program and test.
Note: As long as you are using Microsoft, this is just free.
