Problem with Windows 7 gadgets
I have a problem with my Windows 7 gadgets. I made a screen shot, the image is attached.
I reinstalled all gadgets, but the problem is still there. I am out of ideas.
 Ok, you can try this:
1) Start+R-> regedit
2) You search for Zones folder.
[HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrent VersionInternet SettingsZones
3) Delete the Zones folder.
4) Restart and be happy!
I did your little tutorial like 4 times, every time when I delete this folder it just comes back.
The gadgets are still a mess.
Ok,
Maybe you have some malicious software. Which Antivirus software are you using?
I am using MS Security Essentials and I run full scan every day. I think my PC is clear.
Download AVG free and log in safe mode, then scan the whole computer and you can also use online scanners. A friend of mine got that nasty thing and MS Security Essentials didn't detect it.
It was some Malware. I cleaned up my PC with several AVs and reinstalled my gadgets and now everything is OK.
Thank you for your help mate!
