Problem with Windows 8 Upload.
Hello! I just bought a Dell V14T-5470-A60 with Windows 8 running on it. For the first time, I am encountering an issue. I am unable to upload any files, either by Email, Dropbox or Facebook. In result, I could not download anything. The odd part is that, even though I am using the same Wi-Fi on other computers connected to the same network, my computer is the only one experiencing this kind of problem. Can someone help me on resolving this?
Answered By 0 points N/A #188761
This is not an issue with your operating system. Uploading issue can happens only due to the browser. Use a different web browser and you may not face the same issue. To solve the issue in the current  browser clear the cache of your browser. Verify that you are using the latest version of the browser. Also verify the size limit of the upload file where you are trying to upload the file. Within the upload option if you find two more option ‘upload files’ and ‘upload folder’ then use the upload files option and try to upload a file. If still the issue is not resolved uninstall the web browser and then download and install the same web browser from Internet. A new browser will solve your issue.
