Problem in Windows Internet Explorer 6.
How to disable or enable the Image Toolbar and Automatic Image Resizing Feature in Internet Explorer 6?
There are two ways to enable or disable the Image Toolbar. First is through the Internet Options and second is by using a shortcut menu that is visible when you right-click the toolbar. This shortcut menu will let you turn off the Image Toolbar on the present session or for the entire sessions. Though you turned off the Image Toolbar, it is still possible to right-click on a picture to utilize the conforming commands.
To enable or disable the Automatic Image Resizing IE, click the Internet Options under the Tools menu. And then go to the Advanced tab and then tick to enable or disable the Automatic Image Resizing check box.
Enabling and/or disabling the Image Toolbar feature on Internet Explorer version 6:
Enabling and/or Disabling the Automatic Image Resizing feature on Internet Explorer version 6:
Great!Simple steps made my day. Got it now.. No reason to get irritated on those toolbars. Thank you Tanok! ! Never thought it was just that easy.
You are most welcome. Glad we are able to help you. Let us know anytime if you need further assistance.
