Problem with Windows XP at version X3
I’ve got XP and also not too long ago updated from version WP X3 to X4. I do have spotted over X4 that once I look through over to information the side preview panel displays the actual page however if I search to an alternative folder the preview panel setting modifies itself as well as there's no file until I manually click the preview button. Will there be in any case to form this kind of setting remain for all file previews similar to the earlier variation?
Answered By 15 points N/A #103704
The preview pane is a useful tool in Windows xp as it lets you preview the contents before opening it. To change the settings of your preview pane, do the following:
  • Click on the View menu and then choose Layout
  • Look for the Preview Pane area
  • This should show you all options available for the preview pane, just select on the options you want
For image files, you can set Preview as the default action in windows xp:
  • Go to Control Panel, and choose Folder Options
  • Look for the File Type tab
  • Select the image type and then click on the Restore button at the bottom
Good luck!
