Problem with wireless USB modem.
I am using a wireless internet usb modem for the past 5 months, without any issues. But, when I installed another usb device, the modem has stopped working and shows "There is no device". What can I do?
USB Wireless Internet modem uses a USB driver. This ensures that the modem is recognized by your computer for use by your USB software.
During the course of 5 years, using the USB Internet modem, your computer recognized the USB Internet without any trouble. This gave you Internet access for that period of time.
Upon installing the new USB device – probably a different type of USB and model number – you started having trouble. The problem is that your computer can't recognized the new USB Internet modem you just installed.
What you need to do is to install the USB driver and run the installation CD. Follow the wizard instructions and this guarantees to fix the problem.
