Problem With Saving Pdf File, And It Throws Acrobat Error 110, Refers To Its Solution
Discuss Acrobat error 110? Describe the reason behind the occurrence of this error and give the steps to fix the error message?
Suppose a user opens the system, and edits a pdf file, and tries to save the edited file using Acrobat DC, then an unexpected error will appear that is named Acrobat error 110. The error message will appear ‘The document could not be saved. There was a problem reading this document.’
The steps to fix the issue are as follows:
Step 1: Delete the downloaded pdf file and re-download it.
Step 2: Copy the file on the desktop.
Step 3: Open the file using Acrobat DC.
Step 4: Make your changes and add a new slide after the last page of the file.
Step 5: Save the file with a different name.
Step 6: Open the modified file and delete the new slide from it.
Step 7: Now, save the file with the original name.
