Hi! My problem is with CPU, the usage in Task Manager shows 100% when playing games or using office.. I tries to close heavy programs in task manager, didn't help. Motherboard Gigabyte 8LD533 1.x, CPU Intel(R) Pentium(R) 4 CPU 2.40GHz. I tried to install INTEL 02 CELERON 1.80HZ/128/400/1.75V but still CPU 100%. Will appreciate your help.
Problems with CPU Usage is 100
Hi, Edwardo!
Check if there is any background program running. Background programs can take up memory space and slow down the computer, making it unable to run the main programs. Make sure you have more than 256MB of free system memory. If you play games on your PC, your PC might run out of system memory to run the software smoothly. As you use your computer and run programs everyday, your temporary files grow larger, so it is recommended to delete those from time to time.
Regards, Mathew Tand
