Problems creating and custom Outlook Form
After creating a custom Outlook form and then creating a new item or opening an older item from before the custom creation the form is not being used. Why?
Hallo Lyle Martin,
I think you are not able to use the custom form after creation because you have the option that prevents creation of the custom forms turned on. You will need to check that by and rectify in case it is the one preventing you from using the custom form by navigating to the following registry key:
HKEY_CURRENT_USERSoftwareMicrosoftOffice11.0Outlook
You should look for the DWORD named NoOutlookFormsDesigner, and if it has its value set to 1, reset it back to zero for you to be able to access the custom outlook forms. You should be careful not to mess up the registries for that may cause severe damage to your system, and in that case I will advise that you first backup the registry on a safe place on your computer.
__
Regards
Mahesh Babu
For you instance, I am briefly describing the procedure to put out the form in the form library.
