Problems detected even after solving problems with auslogics
I am using auslogics boost speed software for my pc. Recently there has been a problem with disk clean up. No matter how many times I clean up the disk after fixing the problems i re-scanned  it and it finds almost the same amount of problems each time. Some kindly help me with the problem.
Jayson Mars
Answered By 590495 points N/A #108307
Maybe there is a problem in the file system that’s why the errors just come back after fixing and cleaning them. If you are sure that they are the same errors you previously removed and fixed, then you really need to check your computer for any possible errors. Use a disk utility application to check the system.
For a much thorough diagnostics on the system, use a disk utility application like PC Tools Performance Toolkit.
This tool is very handy in cleaning your hard drive from any unwanted files like log files left by some installation you previously did, temporary files, the deleted files in the recycle bin, web browser cache and cookies, and others.
Before cleaning your hard drive from unwanted files, be sure to check your hard drive first if there is an error in the file system. If there is no problem in the hard drive physically, then you can now proceed on cleaning your drives.
