I just bought recently this scanner. At first I was able to use it without any issues or glitches. Few days ago I noticed that some of my printed documents took a very long time to be scanned and copied. I just ignored it because I thought that is the usual speed of this scanner. It gets more annoying that all documents even in black and white only takes at least 5-10 minutes to be copied. Is there any problem with this scanner? What could be causing this problem? Can you provide me ways on how to resolve this issue?
Thank you!
Problems with Fujitsu Fi7160 Sheetfed in my desktop
I would tell you about this scanner issue I was searching excellent scanner in the market and finally I got it, I hope it would be fine.When I worked in fi7160 it is scanned very fast with excellent results.
The main problem was it would lock up when i take multiple scans.sometimes the buttons on the panel is not working properly and i tried to recover it but it is really impossible to do it.
Finally, I tried different USB ports and different cables but I got the same results I don't know it's a hardware issue or software issue.
Finally, I am staying away from this model instead of trying repaired it.
That is really good sense.
