Problems of Hindi language for adobe page maker
Hi everybody, I installed Hindi language for adobe page maker, but it doesn't include all the characters, is it common problem or because of the version i downloaded? Regard
If this is the first time that this happens, try restarting your computer then try it again. Check it again after rebooting the system. If still not all characters are installed then maybe there is a problem with your previous installation. Try reinstalling the language pack again to fix any missing files from the installation. Uninstall the Hindi language pack then restart your computer when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics test on your machine, use a disk utility application like Norton Utilities. Install it again then check if this fixes the problem.
You may also try downloading the language pack directly from Adobe if it is available. This assures you that the characters in the language pack are complete.
