Hi everyone,
I want to add Disqus to my blogger site but I'm facing many problems to install it. Firstly I tried installing it through Disqus installing instructions but it did not worked, then i tried installing Disqus manually but still its not adding up. So please help me is there any other way I could do?
Problems installing Disqus to blogger?help
Hi Mildred, in order for you to incorporate Disqus into your blogger site, try these troubleshooting method. Sometimes if it was incorrectly installed it won’t provide the expected outcome. Disqus should also be placed at the bottom right column. First, try to reset the corrupted posts in your Blog widget. Now, try to reverse all widget templates back to its original default settings. Next step is to go to your Blogger icon then proceed to Template and then try to edit your HTML tabs. Next, tap the Revert widget templates to default link and from here just hit OK to save it. If you installed Disqus in your Google+ but the comments are not seen try to disable the comments for Google + before Disqus will appear in your Blogger.Â
