I was having a hard time installing Multi Net. There are several errors that popped up whenever I tried to run and install it. There is no available miniport that is shown on the computer monitor or screen snapshot. The window in the network connection cannot also be viewed. I wondered why there is an un-ticked mark in the Multi Net attribute property in my computer’s wireless card. Why is that so? Please help fix this problem.
Problems installing the Multi Net software
Hi Shantell Mona,
    Whenever you are trying to install a software such as Multi Net,  you have to try checking  your Operating System if it is compatible with the Software you are installing.  Because if it doesn't match, the software will not work properly.  Also check the Ram Space.  Because if you doesn't has the available space you will not be able to install the software because a software like that required a much larger space.  After such checking the system requirement and space availability, you're now ready to  install again the software.  Make sure you uninstall the Multi. Net Software before reinstalling it again.
Hope this might help you.
