Problems with installing windows vista
Hi all. I wanted to consult you about the problem I encountered when installing Windows.
The error message stated: What to know before installing Windows: setup.exe – Application or you could see the screenshot below for more details.
I would really appreciate your help.
Thank you!
Error:
The exception unknown software exception (0xe0000100) occurred in the application at location 0x773c3f63
Answered By 0 points N/A #153123
I think you got this error when you go to install the windows vista or when you going to repair windows vista.
The setup of windows vista is giving some instruction before the setup is going to execute. That is the thing that call “What to know before installing Windows” This thing is designed to give some help to install and to make easy the process by increasing the knowledge of the user about the vista installation.
But in you setup one or more file which are related to the help instruction display has been corrupted. That is why your installation gives this error.
If you can continue with this error do not wary about it. If not you have to find another setup.
