Good Day Experts!
I think I have a problem with my Intel Corporation Mobile 4 Series Vista 32. I ’m experiencing a black screen in my display and I tried to reinstall my graphics driver which is Intel Mobile 4 Series Express Chipset Graphics Driver 8.15 but I’m getting an error. Anyone please help. Thanks.
Problems With Intel Corporation Mobile 4 Series Vista?
Hi Alex Sandara ;
It seems like a lot of people are experiencing the same problem with the Intel Mobile Series 4. Here are some few steps you can try that will hopefully solve your problem :
1- Remove every driver you have installed
2- Uninstall your camera driver/software
3- Clean your registry with CCleaner
4- Install all Windows updates
5- Finally use Intel Driver Update Utility to install all missing drivers, here is the link https://www.intel.com/content/www/us/en/support/detect.html
I recommend to reboot your computer after each step and to only use official drivers provided from Intel or from your computer manufacturer's websites.
