I have a problem. I have installed Joomla 1.5 inside a folder in my root directory. I have created the test folder named, "prueba". I installed Joomla 1.5 and installed a template from YOOtheme but it is not working at all.
Please help me out.
Ferdy
5 points
Problems with joomla 1.5 and templates
If your theme still doesn't show in your page, it seems you have a problem with the folder permission. My advice is, you should change permissions of all your Joomla folders to 755, and all your files set to 644. On Cpanel's File Manager, you can see the permissions of your file at the right column.
This is because every server requires their clients to set all file and folder permissions to secure their website. So, if the settings do not fit with the requirement of the server, your website will never show up, and more to say, your web is not secure 🙂
