Problems linked to plasma circuit
Hi everybody, Any idea about how to get rid of the strong noise linked to plasma circuit please. Thank you in advance
The strong noise of your plasma TV may be the cause of one of the problem with sound, television settings, cable connection and placement.
To get rid of this, check for the self test of sound to determine whether the noise is coming from the television hardware or from cable box. Then, check for brightness settings, because in some models, the noise causes due to the electricity used to create on-screen images. Check the cables connection and confirm that all cables between the TV and other devices are plugged in secure since loose connections may result in buzzing or other sound distortion. Sometimes the placement of your Samsung plasma television results in a loud humming or buzzing noise. Then, finally check your TV manual for installing a wall mount unit.
If the problem still persists, contact your plasma TV manufacturer to get it resolved.
Hope the above information helps you better.
