I would like to know if anyone else has encountered my problem with Live Communications Server (LCS) 2005. It will not start and the event log indicated that the LCS is an expired evaluation. I suspect that there is an incompatibility between MS09-056 (KB974571) and LCS. Can you help me find out why this is happening? Thanks.
Problems with Live Communications Server 2005
Hallo Ms.Catherine Tucker,
If Live Communications Server cannot run and it is displaying an error message that it is an expired evaluation, then it pretty clear that the period you were meant to use it has come to an end, since it was a trial version application. You will therefore need to get the full version of the same, by either purchasing online or from a supplier near you who sells such kind of an application.
I do not think this is an error due to compatibility issues because the error message to that could have told you something the LCS cannot be supported on the system you are using.
Hope this helps.
__
Regards
Mahesh Babu
