Problems with my computer Please help
Hi Everyone ,
As a new member in forum, I am in little bit hesitation to share my computer problem which is running well Battlefield BC2 and CoD MW2 with smooth display.
But recently its flickering and failed to solve by driver update.
My pc spec is in below:
CPU – Intel Core i7 X4
GPU – AMD Radeon HD 6800
Operating System – Windows 7 64 bit
Thanks
Best Answer by Alber grower
Answered By 0 points N/A #97567
Try changing your memory or remove one if you have two inside then interchange port and one that is attached. Use eraser to clean those memory first before plugging it in. If you found out that it is memory related the I suggest that you buy a new one.
Next is to try the Video Card this time. Remove it and then use the eraser once again. The plug it back in.
If no improvements appear, then try other video cards if you have a spare one.
Hope that this solution fix your problem.
This what I did based on my experience and worked for me.
I hope that it works for you too as well.
Answered By 590495 points N/A #97569
A gamer like you requires very high specification to play games smoothly. A clear graphics display and a fast moving computer is all you need to have. It is a requirements to get this high specification for you to play games as long as you can.
The specification you have posted is good enough to play games. However, you'll need to install better than this. Get more specs that can run better and perform greater than this.
If driver updates is what you are having trouble updating then the possible issue here is a compatibility of the games you've installed and the software you have used.
It could also be the hardware and software on your computer needs some update to function accordingly.
Go to Start, Control Panel
Click on Hardware and Sound
Select Device Manager
Look for the icon says Scan for Hardware Changes
Insert the CD provided by the manufacturer of that hardware or games
This update all the drivers needed both hardware and the actual game
Answered By 0 points N/A #97570
Thanks Alber Grower and Sharath Reddy!
I followed both your solutions and found out that it's my video card. The video card do not meet the requirement of the games.
I also upgraded to a higher memory.
Thank you both for the help!
TechyV is the best!
