jhonny jack
30 points
Posted on - 11/16/2012
Hello everyone,
I had some problems with my USB Skype cordless phone 7100. However, after I set up the windows vista PC 2007, everything went back to normal. I can now receive the bell ring on the cordless unit only that I cannot hear any sound from it, what could be the problem here?
I would gladly appreciate your answer.Â
Problems with my USB Skype cordless phone 7100
I will give you some possible solutions and hope one of them works with you:
1) Â Use it with Skype version 3.8 or less, newer versions of Skype don't work with Skype phone 7100.
2) Â It's better to use it with windows XP as many users have problems using it with windows vista.
3)  You have to enable "always run in compatibility mode".
