maryam Tom
Posted on - 11/02/2011
Hi All,
I am having problems with my Windows Server 2003. After I installed the domain and try to create another user, I receive an error message saying that I don’t have the privilege to create another user and that I have to log in as the Administrator to be able to do it. Please help me find a solution. Thank you.
Jackman
Problems with my Windows Server 2003
Hi Maryam,
This is a very easy task if only you follow the right procedure, please follow the following simple steps to create your new user account. Click start then select the administrative tools and then click computer management. Click on local user and groups on computer management. Then click twice/double click on user's folder. The right click on the user's list and then click on the new user. Fill in the information for the new user and click create you can create another user if you want then click close when you are done. At this point you should be able to see your user account in default.
