Problems that occurred in my new printer
A month ago I bought a printer and after, I pair it to my computer via the WiFi network at home. The printer was not detected by the existing computer in my house.
Specifications:
HP DESKJET 1360
What should I do? Can you give me a solution? I have tried several steps to connect the printer, in addition to using the WiFi network, I have also tried using a LAN network, namely to do with peer to peer connection with another computer through a switch. but the printer can not be connected. Which oddly enough was the printer can be connected to my computer directly, if not through the network. what wrong my printer? Why with my printer over the network is not connected with another computer?
