Problems with online converter and DVDPedia export:
Hi!
By using the online converter I wanted to convert my DVDPedia export but I get the following error although the file is rightly encoded.
"Unable to parse XML file. Is it encoded in UTF-8?"
After a lot of test and failure, I believe I have narrowed it along to the converter. If the export library holds only 3 records, I am able to run an export through the converter.
But if the exported library holds for 4 or more records, it shows the error message. I have 600 records in DVDPedia in my library and truly I want to get them into HD Movies.
