Is anyone familiar with Android programs here? I’m having trouble playing a video with my Media player. I’m using an LG Optimum One Phone, and every time I open a video it only plays a couple of seconds then this error appears; “Media Player: Error in Media Player.” Any help would do. Thanks guys!
Problems playing videos on my media player – Help please!
Hello Mr. RobertCBusch, You may have to update your software on your phone
Go to Home page on your phone
Locate about phone tab
Click on System updates
Select Update profile
It will take 2 mins for your network to prepare the data services
Once the completion is finish click ok
Select Home
You may also need to uninstall the app.
Click on setting from the home page
Select applications
Scroll to Manage applications
From either download tab or running tab locate the app you downloaded for media player
Select uninstall
Once you uninstall you will want to reinstall.
