Problems related to Dell laptop
10 points
Posted on - 07/27/2011
I have a D630 running Vista Ultimate 32-bit with the Dell 360 Bluetooth adapter. I don't know what is going on. The adapter is turned on in the BIOS, and the wireless switch is turned on. Device manager says it is working correctly…but it isn't.
The system tray Bluetooth icon is blue with the Bluetooth symbol white. When I right-click the icon in the system tray I get the shortcut menu, but I don't have the option to "Turn Bluetooth adapter on" or "Turn Bluetooth adapter off". The Bluetooth LED above the keyboard does not light up and therefore doesn't work even though Windows says the device is functioning properly.
When I go to Network Connections and right-click the adapter and select "Diagnose" I get the following message: "Windows found a problem that cannot be repaired automatically. Contact your Internet service provider or network administrator for help or click here for information about things you can try to help resolve the problem."
If anybody has any ideas pass them on
