allaine
Posted on - 11/14/2011
I am having lots of trouble with my server. One problem is the connectivity problem between my DNS and SL.
I cannot play my Snow Leopard unless I use DC as the only DNS server. Another problem is that my SSO cannot function properly after trying every troubleshooting. It regularly asks for authentication before I could log in.
Given that the configuration of my network of Mac is connected to older Windows 2000 Server AD environment.
Why is it that I encounter such problems?
Trevor
Problems relating with server connectivity.
This problem is commonly encountered with the time settings from the server and on the client machine is not match or sync. What you need to do is to set your local machine or client computer to the date and time set on the server so that when you connect in your server you will never be prompted by a bogus log-in dialog box to enter your user name and password every time you connect to the server. But off course be use that you have the proper credentials to access or join your server. If it is none, try to contact your system administrator and as for the access on the server for your computer.
