Problems with Rising Antivirus 2007?
Hello TechyV Experts!
Has anyone tried the Rising Antivirus 2007? I am an avid user of a free antivirus but I am curious with Rising Antivirus. Is it a good antivirus program? If it is, then I will switch to Rising Antivirus. Can anyone please tell me your experienced with Rising Antivirus? Have you encountered any problems with updates or with detecting and removing the high risk viruses? Please share us your knowledge and expertise. I need to know if I will be using the best antivirus software or not.
Please guide me.
Answered By 0 points N/A #150713
I don’t use it but my sister does. A friend of hers recommended it to her and so she tried the trial version. She seems satisfied because just last month, she purchased the full version.
According to the reviews it has more pros than cons. My sister even told me that it’s prettier than any AV that she knows. Though it is not as famous as the other AV in the market, this software is doing its job very well. Another advantage or maybe the biggest advantage of Rising AV is its price. It is a lot cheaper than any other AV around.
You may want to try the trial version for you to experience it. Follow the link below:
http://download.cnet.com/s/rising-antivirus-free-edition/
