Problems in running ConfigMgr 2012
I think I did a mistake by running the ConfigMgr 2012 as not an Administrator.
An error message popped up while editing a report, which is shown here.
Is there any way to rectify this?
Error:
Report Builder not available
Report Builder 2.0 is not installed as a click-once application on
report server 'ctcm01.coretech.intra'.
Go to
http://www.microsoft.com/en-us/download/;
n&FamilyID=66ab3dbb-bf3e-4f46-9559-ccc6a49dc19' for
Download information.
Answered By 0 points N/A #148493
You have solution right in front of you. Just open the link in the error message. It will give you new download information. You just need to read instruction careful. Do it step by step.
The proper installation will start before downloading the installer. I think that it will ask you to download Microsoft .NET Framework and after that you can just install it.
Other solution will be checking our system for any errors. You can use some software for that. Run any software of that category and see if your system have errors to repair them. I suggest to you to use Toolkit. It will repair all errors on your hard drive.
Hope i helped to you
